Pain in the ass
jOCA
Unread post by jOCA » 19 Apr 2016, 23:25
It's really a pain in the ass to start working with Hollyhock. For a long time I didn't use Usine and this changes are a lot better. I really like it now. But to do a simple thing as to play my guitar inside HH it's really a nightmare. So simple and so complicated. We have to look fo the Mic, put the Mic inside the Track, see if the levels are correct, and they aren't at all. Look for modules, try to import VST's that crash (some thousand...|. When that could simply be done by those workplaces that are pre-done.
Amazing those sounds, loops and applications. It's really a must. Love it, but as I got an old laptop I have to take a lot of care. From Ableton to Audiomulch, to Reaper and now DVstHost, after looking to N-Track 8, Hollyhock could be the best. If you would like a localization into portuguese I'll might try to help. :D
Thank's for the good work.
Unread post by senso » 17 May 2016, 11:03
thanks for your comment,
some templates are missing but you can add new in the /Resource/Templates/ folder.
Unfortunately we are not Portuguese fluent. And a translation could be an hard job (around 1500 pages in the wiki)
senso+++
Users browsing this forum: No registered users and 123 guests
