issue with writing a text file from an array
fractalist
Unread post by fractalist » 18 Apr 2016, 13:35
Problably something I misunderstand in the available module,
so I introduce the question globally :
I have an array, which contains a series of values, and I want a text file containing all the values (separated somehow) so I can analyze it elsewhere.
thanx !
(PS : I thought : array connected to "array to comma text" connected to "write text file" but I can't make it work? I guess I do something wrong, it's probably simple).
sephult
Unread post by sephult » 18 Apr 2016, 18:51
ARRAY MANAGER
Here is an array manager I made, that I havent released yet. It allows you to save and recall arrays.
It places I believe under Config/ it will create a directory structure for data.
-s
fractalist
Unread post by fractalist » 19 Apr 2016, 11:54
Thank you Sephult !
However, I don't understand how it works : I can't see anything / any object/module whatsoever in the patch.
I got that there was a preset manager in the GUI but that's it.
Also, if someone from senso could chime in so I can learn on that matter as well, it would be cool ! (I can't make write file to wrok)
sephult
Unread post by sephult » 19 Apr 2016, 12:30
Sorry fractalist, i guess I uploaded the wrong file...I will have to look through and see if I have it still.
I had to use scripting for mine, using the write/read scripting example started me out on doing so.
-s
fractalist
Unread post by fractalist » 19 Apr 2016, 12:32
No pb. I'm on mac, if it helps you !
"Write text" is working for me now, still not sure what was wrong !
sephult
Unread post by sephult » 19 Apr 2016, 12:38
Working Array Manager
I think this one should work, but I am using PC...so I am not 100% sure if I was neutral to the directory structure.
Its been awhile since I did this one
-s
Unread post by nay-seven » 19 Apr 2016, 13:39
for me the basic patch works here ?
here I'm on Mac, the file has no path, so it's been written in the Usine appz package
Download
Unread post by 23fx23 » 19 Apr 2016, 21:33
on windows it might be just some right/privilèges thing to write file, i made once a user module willing to write wav file that seem wasn't working, but running usine as admin via right clic allowed the file to be written at root folder
Users browsing this forum: No registered users and 184 guests
