So i uploaded into addons my Euclidean Drum Sequencer
here you can find some showcase how it works
https://www.youtube.com/watch?v=bxzWvH4RFR4
In the right top there is global override for quick setup of all tracks in sequencer.
bpc - beats per cycle - so you control with it how long it take to make whole cycle
note - which note is triggered
base vel - base velocity
steps - how many steps are in the circle. so the note length and the rhyrhm is controled by beats per cycle and stepps in the circle.
pulses - configuration for euclidean generator - it is the number of how many of the steps should be trigered by euclidean rule
accents - is the number of pulses which have accent (velocity 127)
generate - triggers the euclidean rhythm generation
clear - clears the pattern
rotate - turn the "rotation" of the rhythm
r after - rotate after X steps in the circle
r steps - rotate by X steps when rotation is trigered
Circleseq v2 - Euclidean Drum Sequencer
I think I'm gonna use this...
