Simple question... how to add a pitch bend fader?
edhombre
Unread post by edhombre » 22 Mar 2016, 10:37
New to Hollyhock and using it for live performance. My controller is a Nord C1 organ which has 2 keyboards but no pitch bend. I'm using a little windows touch screen laptop for various sounds and building patchs with faders etc for the parameters I need to control live and it's going great but I can's seem to work out how to add a simple pitch bend controller that I can use just as I would a pitch bend on a physical keyboard ! I appreciate this is pretty simple but I just can't seem to get it working! Can anyone post a simple tutorial/point me in the right direction?
Many thanks!
edx
edhombre
Unread post by edhombre » 22 Mar 2016, 10:49
BTW I'm trying to get this working over midi so it has to combine with the incoming midi feed from my keyboard.... not every vst has a pitch bend parameter I can map to directly.
Unread post by nay-seven » 22 Mar 2016, 14:25
Here an example with the create Midi module, knob value is 0/127
add a Midi learn on this knob to create your pitch bend
Users browsing this forum: Google [Bot] and 13 guests
