Audio Aux In and out
Unread post by cmodica » 21 Mar 2016, 20:42
Hi all.
I need to send the audio out of the racks in the Audio in of one or more other racks. Ok it is easy to do. But i need to select when i perform in live session witch Racks Output i send in witch Other Racks Input.
So i need to build a sort of ''Aux Audio Chanel Send and receive''. Somthing that i can use as a patch or Device in different workspace.
I need the possibility to chose in a rack the Aux Out 1 or 2 or 3 or 4 etc, and the possibility to chose the Aux In 1 or 2 or 3 or 4 etc
Is there anybody who can give me the better way to do that ?
Unread post by cmodica » 27 Mar 2016, 20:30
I find a way to manage it. These are the patches i build for that :
download In And out Selector
But i didn't find a way to use it as a device. Because i need to have the selectors visible on each rack. But if i use my patches as device, only one instance of the selctor appears in the interface builder.
Maybe there is no way to do that with device ?
Thanks all.
