zoom whole workspace/IB
La Tenaille
Unread post by La Tenaille » 12 Mar 2016, 22:52
...as in HH1. So usefull to switch from detailed to global view, or quickly resize from screen to screen.
Unread post by senso » 21 Mar 2016, 23:06
there is already an option in the setup for global zooming?
La Tenaille
Unread post by La Tenaille » 23 Mar 2016, 23:07
yes, but then the soft controls become too small... I use the same workspace on different screens.
Unread post by woodslanding » 11 May 2016, 06:29
My wkp doesn't fit on my laptop screen. I wanted to zoom it out as in HH1, but when I use the global zoom I still can't see my wkp. There is now just a black space around the IB, but the controls that are out of view are still not visible....
Vaga
Unread post by Vaga » 29 Jun 2016, 20:24
I'm having the same issue. I have a 12.5 inch 4k screen (Dell XPS 12). If I change the global zoom control to anything greater than 1, there is no way to see the settings menu anymore. Also, with Windows DPI scaling on, everything looks soft and not crisp. With DPI scaling off, everything is too tiny for use.
At global zoom of 1, everything is just a little bit too small for use with touch on my device.
