I think there should be a global quantize option for preset selection.
I tend to want to have the option, however whenever you need it you have to manually set quantization for each and every preset which makes it cumbersome.
-s
Global Quantize for Preset Selection
- senso
hum...
the problem is to have both different options : global quantize and a different local quantize.
which should be the winner?
I feel tricky behaviors....
sephult
I see where you are going Senso, definitely could be a tricky thing...
Possibly a momentary button that acts as a Macro, you could set your quantization and press the button and one-time it sets all the presets to that quantization? Could also have a reset quantization, which sets all preset quantization back off.
-s
-s
