Hey all,
I like the Looper Peakslicer a lot, however:
When I sliced something (and even saved the individual slices to disk) it still looses the samples/content on project reload.
I get a lot of "missing files" error-messages. I don't know if it is just not possible to save everything or if there is a mistake somewhere.
I am on OSX if that helps.
tL.
Nay's Looper PeakSlicer
- nay-seven
At first this patch (senso work) is a live tool, not really done to save with the pach, but here a different version: Download
here how to process:
-select rec num=0
-record
-save current
then
-select rec num=1
-record
-save current
and so..now you can swap between records
save the patch and your samples will be saved with it
-select rec num=0
-record
-save current
then
-select rec num=1
-record
-save current
