Audio patchbay module ?
Unread post by sm_jamieson » 11 Mar 2016, 11:28
Is there an audio patchbay module or add-on that can be dynamically controlled using midi learn, etc. ?
Relating to this post:
http://www.sensomusic.org/forums/viewtopic.php?id=5351
Unread post by nay-seven » 11 Mar 2016, 11:42
The audio matrix + Midi learn on a preset manager will do the job ?
CREDO
Unread post by CREDO » 11 Mar 2016, 17:46
The audio matrix would work for this, but it also adds an extra block of latency...
Unread post by senso » 11 Mar 2016, 19:19
CREDO wrote:The audio matrix would work for this, but it also adds an extra block of latency...
not shure....
Unread post by oli_lab » 12 Mar 2016, 16:49
Actually audio matrix are great for multichannel spatialisation
And also for complexe audio patching
One tip :
Multiply the array output by another array with cells set to 0 to avoid dangerous feed back
