Does Usine have a switch that does not latch ?
It needs to generate a 1 when the mouse is down or the finger is touching, and return to 0 on mouse-up or when the finger is removed, i.e. a momentary action.
The button generates a pulse when pressed.
The switch toggles when pressed.
Neither of these can be set to behave as I described.
The solution could be a script, patch, module or user module.
