Issue piano roll num file grid
drumaddict
Unread post by drumaddict » 31 Jan 2016, 12:08
I write in English this time because i didn't have any answer in French. :)
I'm a new user of Usine, i find this software totally crazy and powerful. But there are still some few bugs that bother me.
When i'm trying to send midi notes from a piano roll section to a vst there's something wrong.
In fact, the first loop of the piano roll in the grid never play correctly, I have to wait for the second loop to hear something. It's like the trigger doesn't work.
This problem also happen when i try to switch the num file of a piano roll located on the grid with a step curve automation.
Do you have any solutions for this issue ?
Thanks and keep up the good work.
drumaddict
Unread post by drumaddict » 02 Feb 2016, 11:10
I have just noticed that the problem is from the automation "step" curve which send an "off " note just after switching to another num file.
Because when i use two different racks, so with two piano rolls for switching from a midi score to another, everything work perfectly.
It is a bug ? Or a mistake i made ? Someone have the same issue ?
Thanks.
sephult
Unread post by sephult » 02 Feb 2016, 12:41
I've had issues with the grid and piano roll as well, I believe this was also a confirmed one that I had brought attention to.
Interesting your find about the note off. Is this an "All note off message"?
-s
drumaddict
Unread post by drumaddict » 02 Feb 2016, 15:10
Ho yes an answer !
I have just checked, it's a simple "note off". In fact, it send a "note off" instead of a "note on", as you can see in the screen.
[img]http://www.sensomusic.com/forums/upload ... ue.jpg[img]
The problem is definitely from the automation curve because when i switch the num file manually with a fader there is no problem.
drumaddict
Unread post by drumaddict » 02 Feb 2016, 15:11
Here is the screenshot :
sephult
Unread post by sephult » 02 Feb 2016, 23:09
Have to have Nay see this, maybe he knows a little more about now...or possible this could help them find the issue.
I generally try to do it not from the automation curve, but I have problems with both the curve and switching the rack presets.
-s
Users browsing this forum: No registered users and 178 guests
