I'm traying to make this work... It's there. I've set all the prameters of the card and in Usine's setup, but I still cannot receive any data.
(cables OK, Leds showing stream, etc.)
I'm miss something, but what?
I've created a new OSC In device but I cannot drop it in the rack input. ???
I've dropped an OSC lister module and an OSC Receive in the patches (device or not device, that's the...), but there is no life in them.
Thanks for any help if you have ideas...
Vincent
Working with Interface-Z OSC card
vincent michel
composer & novelist
composer & novelist
i don't know how this type of interface works, but do you see activity if you trace udp in the setup/network tab ?
Thanks Yan, I finally had the idea to open the trace window and see there was no activity...
I've fix the pb this night... it was just a power micro-failure!....
Everything is OK now, and it works very well.
vincent michel
composer & novelist
composer & novelist
Good news !
Users browsing this forum: No registered users and 28 guests
