6Appeal Parameter Editor
shawnb
Unread post by shawnb » 18 Jan 2016, 04:46
The 6Appeal.pat patch is a parameter editor for Spicetone's 6Appeal distortion box. The 6Appeal is the ONLY fully analog hex distortion pedal out there. It sounds *glorious*.
Note that Spicetone has released an editor as well, that offers full read-write capability. (This editor is write-only.) But this editor is helpful for learning the product, as all parameters are visible on one screen.
To use, make sure your MIDI OUT finds its way to the 6Appeal's MIDI In port.
This editor utilizes the extensive set of MIDI NOTE & CC messages that Spicetone has documented in the 6Appeal manual.
For more on the distortion pedal:
http://www.spicetone.com/
Also over on VGuitarForums:
http://www.vguitarforums.com/smf/index.php?board=179.0
Unread post by nay-seven » 20 Jan 2016, 08:47
Don't have this pedal, but thanks to share !
