I'm dealing with loss of time in resizing things onto the C.panel with big patches. If only you could multiple select objects and resize them by dragging just one corner would be very helpful.
to me the ergonomic of a workspace is something important.
Also I'm experimenting some troubles with audio damage plugins. The owner updated them and the au validation from the editor is passed , but when loaded into rack look/(the video in the uploader) what happens. Is it a plugin problem or usine problem?
1 suggestion & plugin problem!!
The multiple resizing and moving, is one that has been requested for some time and they are aware. I know what you mean, I have a habit of building then redesigning the GUI many times before I am happy. I believe this is one thing that is a problem or difficult with the coding software they are using, I do hope that someday as well they can do multiple object selection/resize.
-s
-s
Users browsing this forum: No registered users and 79 guests
