External devices
gillesdanger
Unread post by gillesdanger » 17 Dec 2015, 11:43
My card is a 6 inputs. I see those input in usine. I patched every input as one instrument by input card. So I was thinking to be abble to switch of every single sound intrument in every patch where those input had been added.
For exemple in cubase It's a little monitoring icon, witch turn on and of the signal coming in the input of the card.
So my problem is that I always heard my instruments.
Someone to help me?
sephult
Unread post by sephult » 17 Dec 2015, 12:47
In the device input section at the top of the rack, each device input should be listed. There is a little green dot to the right, I believe if you click this dot you can enable/disable each input as required. Is this what you are asking?
-s
gillesdanger
Unread post by gillesdanger » 17 Dec 2015, 13:23
Thanks Sephult.
Yes I tried that to. Even if I turn of every single input that I can find, including in the main control center (from the gear icon) I still heard the instrument input. I'm wondering if the is something abnormal between steinberg ur 44 and usine input manager…
sephult
Unread post by sephult » 17 Dec 2015, 19:07
Thats strange, these buttons should enable and disable. Do you have passthrough monitoring on within your steinberg?
I know sometimes I run into that, but it's because I have the inputs routed to the mains within my Focusrite scarlett Mix Control.
-s
gillesdanger
Unread post by gillesdanger » 17 Dec 2015, 19:47
Great Sephult,
You put me on the right direction.
Steinberg is using a DSP mixer which I only have to level down to zero every channel rack.
Thanks you and well done !!
Gilles
sephult
Unread post by sephult » 17 Dec 2015, 23:37
Good glad to hear!
-s
Users browsing this forum: No registered users and 197 guests
