Help with overlapping audio clips.
Vas
Unread post by Vas » 05 Dec 2015, 08:43
New Member here.
I like to to do audio sample montage. This involves overlapping two audio clips with fade-ins and fade-outs. Then when I like the result to bounce them in place. Is this possible in Usine Hollyhock?
Windows 10-64bit, i9, 32GB RAM, Studio One 5, Reaper 6, FL Studio 20, Komplete 11,
Unread post by nay-seven » 05 Dec 2015, 09:07
of course Usine is not a classic timeline daw, but each sample can have a volume curve so you can create your fades easily,
You can also create curves in the grid. Then you use the direct to disk or recording patches to bounce the result.
Users browsing this forum: No registered users and 72 guests
