Questions on the "Patch Settings" module
Vincent
Unread post by Vincent » 03 Dec 2015, 19:05
I'm wondering about the "enabled" inlet of this module.
It corresponds to the enable switch in the toolbar header and it's fine to have access to it. But what is the real difference between a non enabled patch and a patch with a "patch On/Off" module set to off (specially regarding CPU load and threads)?
If there is no difference except the greyed interface of the patch, could the "patch On/Off" module also turn the interface to greyed when it's Off?
If there is a difference, could this "patch On/Off" function be also founded in the "Patch Settings" module, since to be On or Off is some kind of setting ?
Thanks for your answers!
Vincent
vincent michel
composer & novelist
La Tenaille
Unread post by La Tenaille » 05 Dec 2015, 11:35
The patches are supposed not to be calculated when disabled, but I'm too interested in a precise staff answer :)
Vincent
Unread post by Vincent » 05 Dec 2015, 13:23
When you connect a switch to the enabled inlet, you can turn this 'off' and disable the patch. And when it's off, you cannot turn it 'on' anymore (because the patch is disbled!). The module Patch On/Off works differently.
It's confusing...
vincent michel
composer & novelist
La Tenaille
Unread post by La Tenaille » 05 Dec 2015, 19:18
You're right. I've never used modules to disable a patch. I only use the enabled pin of subpatches.
Vincent
Unread post by Vincent » 05 Dec 2015, 20:06
Yes, it is the simplest way.
But sometimes it's necessary to do some stuffs in the subpatch just before disable it (like mute audio to prevent from looping the last audio block). That's the reason why I also use this module Patch on/off connected to an 'on' inlet or to a switch with two links: one direct and one passing through a 'wait one bloc':
Code: Select all
Switch_________________Patch On/Off
      _____Wait1_____/
sometimes this WaitOneBlock module is replaced by an enveloppe tracker that falls to 0 when the module has finished with delays or reverb.
Anyway, some precise answer will be welcome!
vincent michel
composer & novelist
