Hi
On usine 5 i could "listen" artnet with receive byte module
As artnet is implemented on the new version it's impossible now (i imagine that is the reason).
So is it possible to imagine now artnet receive integrated with universe select to get an 512 array values ?
artnet in
- senso
you still can use the receive byte module?
and there is no artnet input in Usine, I know I should implement it.
