crash
My session crashes systematically. When I open it, if I try ton insert a Sixteen Pads, this one doesn't appear, if I try to save it, it already crashes... I've tried many times, clean my computer... (MacBookPro10,1 OS X 10.9.5 Maverick, Intel Core i7,
2,7 GHz, 1 processor, 4 cores, 16 GB RAM, / Usine Pro RC11 2.0.060 OSX32). It was ok until now...
How could I solve the problem?
Thank you
Gwennaëlle
Thank you
Gwennaëlle
Maybe something is corrupted in your config folder, try to unzip a new Usine.zip and test again
Thx to reply.
I had erased a track with several effects, and it becomes ok. But this is temporary, cause I will need this track. So I try with a newer version of Usine, the one in Dropbox, Usine Hollyhock MacOSX 2.0 080. And it's wrote that I'm not registered, and Usine is not free... But I am. Isn'it a update?
last version is on the download page, 081b
you need to enter your logins again, if you don't want to import your old settings
Ok, I learn slowly the use of Usine.
So I try to open my workspace with this new version, but doesn't work.
First it speaks about Impossible to read or open certains audio files (from me and from Usine) so I deleted them. I could open it with the Usine Pro RC11 2.0.060 OSX32 but not with the 081b...
Then in 081b, no message, no opening, it crashes...
Can you create a ticket for this one please ?
Users browsing this forum: Google [Bot] and 18 guests
