Ok, som i am now working on one project, using several workspaces.
Once i tried additional workspace but, it was playing together with main workspace, is there some posibility to have main workspace playing and additional workspace not playing and vice versa ?
- nay-seven
by default no, but you can create a workaround to mute the racks with a patch and a preset manager
here i use the letter V to switch between the 2 workspaces
of course you have to save the presets for the 2 wkp
here an example
Download
here an example
Download
drakh
oh, thanks i'll try that.
nay-seven wrote:by default no, but you can create a workaround to mute the racks with a patch and a preset manager
here an example
Download
