Timefreezing in hollyhock
el-bo
Unread post by el-bo » 31 Oct 2015, 13:46
Hi
Is there anything in Hollyhock that can freeze/stretch audio as well as this ?
https://www.youtube.com/watch?v=lAZqNe-lhq8
Unread post by oli_lab » 01 Nov 2015, 18:51
you could have a go with few instances of the grain sampler + some enveloppes ?
el-bo
Unread post by el-bo » 01 Nov 2015, 19:27
oli_lab wrote:you could have a go with few instances of the grain sampler + some enveloppes ?
thanks for the answer. will look into this as i become a little more familiar with the territory. just hadn't come across much in this realm. pitch is handled extremely well, but i can't seem to find anything for time-stretching., and freezing
guess i need to read the manual :P
Unread post by nay-seven » 01 Nov 2015, 19:34
In the library/audio fx/freez/ you can also find some freez patch like the "Freez hold sound "
with a small value, around 100 ms, it can give good result depending of the source
add the reverb patch to finalize
el-bo
Unread post by el-bo » 01 Nov 2015, 19:36
nay-seven wrote:In the library/audio fx/freez/ you can also find some freez patch like the "Freez hold sound "
fantastic, thanks ??
anything for straight-extreme timestretching e.g ircam, paulstretch etc ??
Unread post by nay-seven » 01 Nov 2015, 19:42
When you drag your sample, choose grain sampler and set the speed to a really slow value, will do the job !
el-bo
Unread post by el-bo » 01 Nov 2015, 20:07
nay-seven wrote:When you drag your sample, choose grain sampler and set the speed to a really slow value, will do the job !
perfect !! sounds great. the freez effect is interesting, and might get me there, but i need a little more practise with it (things are pretty garbled at the moment)
will give it some more time over the coming days
thanks for your help :)
Users browsing this forum: No registered users and 965 guests
