DISPATCH AUDIO BY GRID SECTION PASSAGE
I put a toggle to switch the dispatcher through a button. But what is the impulse or data that the grid emits when the cursor reach the end of a section?
Generally, the best way is to provide an example patch or workspace to ask for help,
cause in Usine as you know now, there's always several ways to do things
here a workspace example of a way to trigger a dispatcher with the grid envelop
Download
Download
Thanks Nay,
I upload my patch. I didn't understand how your patch works. I saw on off-caption value dispatch1 but what is it?
http://www.sensomusic.com/forums/upload ... 201.01.wkp
Ok I got it, you automated the switch with a curve. But it doesn't work if the section is looped doesn't it?
thx
thx
you ask for a change "when the cursor passes the end of grid section"
so in the workspace i've uploaded, if you pass from section 1 to section 2 the dispatch value change if this is done automatically (with a blue arrow) or manually (with the next button) ?
in the wkp you upload, there's no dispatch and the rack is not in the grid so...??
Yes Nay,I just wanted to show you my method if the clock module was right to do so, but it doesn't, t syncs with master tempo not with the grid. However how can I make my patch "detect" when the cursor reaches the end of a grid section? even if it is being looped..Your method is an automation, won't work with looping.
And also, is there a way to change pass to next-loop-repeat x1/x2 value on the top of the grid with a midi command?
Thx
Thx
In modules/interface controls/usine panels/ you have 2 modules you can check
Grid section settings
and
Grid settings
and
Grid settings
Thx Nay,
sorry for such a simple question for you, I'm still a beginner
