store curves in preset
Pianoscope
Unread post by Pianoscope » 19 Oct 2015, 00:15
It would be really useful to be able to store curves 'on' and 'off' state in presets, as modulations can be an intrinsic part of a patch.
Curves are really useful to me for one reason, being able to set their duration allows easy creation of polymetric and polyrhythmic modulations, something that is not possible in the grid.
Furthermore it would be useful to be able to name them, as I sometimes have over a dozen curves modulating at the same time, it can be difficult to match them up with the parameter they are effecting.
Polyrhythmic capabilities of the grid would be a good alternative, perhaps each curve in the grid could have it's own locators, loop points, or the ability to set it's duration independently of the grids section.The longest curve would define the length of the grids section.
Are there any other ways to get polymeric modulations going that I am missing?
Unread post by senso » 15 Dec 2015, 12:05
hello,
quick answer.
1) store on/off state in presets: ok, will be in the next major release
2) possibility to rename : ok in the next major release
3) polyrhythm in grid. not so easy to implement. I'll think about it.
senso++++
