Hello Usiners,
Just a small suggestion:
would it be possible for the filter, delay, and volume audio modules to have a switch (and an inlet) for bypass.
I know it easy to build with a small amount of existing modules, but I think it would be really practical to have it implemented in the modules themselves.
What do you think?
Best regards,
B.
Bypass switch for audio modules
hello
Good suggestion. Can be turned into "Dry/wet" fader.
But it's so easy to create a sub-patch to do that... and so hard to implement it directly in Usine...
Also this function will probably increase the CPU load for in most circumstances, and add a tiny improvement for particular applications.
So I'm not sure...
So I'm not sure...
Just to say that I've posted a series of subpatches containing audio modules with a dry-wet fader.
Rgds,
B.
Rgds,
B.
