Record Automation grid in audio file
Unread post by cmodica » 13 Oct 2015, 14:02
When i use a curve automation in the gridline, the automation volume is recorded in the stereo output. But if i record all my Racks as independent tracks for postprod mix for example, the automation curve are not recorded.
Example :
I use a volume automation curve in the grid to fade out Rack 1, Rack 2 and Rack 3. Everything works fine. But the fade out is recorded in the stereo output but not in the Rack out 1, 2, 3. So i had to fade them manually in the post prod mix.
It should be great to have the possibility to record it in the independent Racks output audio file.
I built a patch ''Vol pour REC'' for recording each Rack with the right volume that i play in the performance.
But the Vol automation curve in the gridline seems not to be link with the rack Gain-output ...
Users browsing this forum: No registered users and 526 guests
