Additional Workspace issue
Pianoscope
Unread post by Pianoscope » 11 Oct 2015, 21:22
Hi
The additional workspace is a real big thing for me, so bit anxious to get it to work.
When I switch workspaces in the playlist after activating the additional workspace (via midi controller)
I the audio stutters and drops out.
Any setting I can change to get the additional workspace feature to run correctly?
Leon
Unread post by nay-seven » 17 Oct 2015, 20:09
have you try this with the demos workspaces included in the library ?
you can also try different audio configuration ( increase buffer size for ex)
Pianoscope
Unread post by Pianoscope » 18 Oct 2015, 23:56
I'm not keen on increasing the buffer size as I am doing realtime audio manipulation with no sound generation.
It is Cpu related, but the strange thing is I can run both workspaces together ok, it's just the cpu spikes when loading workspaces.
Keeping my set going without pauses is a real problem, as I have no spare audio channels, and fairly close to the cpu ceiling.
Users browsing this forum: No registered users and 468 guests
