get IP address
XpiR
Unread post by XpiR » 22 Sep 2015, 13:20
Hi
Is there a way to get the IP adress my computer is connected to and send it in a patch ?
My problem is : I use some OSC send modules, and my network address is dynamic, which obliges me to reprogram my OSC Send [ip name] everytime the address changes. Quiet annoying.
Unread post by nay-seven » 22 Sep 2015, 14:14
you can use the setup panel module (Modules/Interface control /usine panel)
Create a bus from the the Ip adress outlet to use it in your patches.
XpiR
Unread post by XpiR » 22 Sep 2015, 14:35
Great, thanks Nay, that's what I was looking for!
