Bug in the text component formatting
martignasse
Unread post by martignasse » 23 Jul 2007, 22:56
seesm's like i found a minor bug in the text component formatting :
Imageit happen when resizing the text.
Unread post by senso » 25 Jul 2007, 09:35
could you describe the bug?
I can't see it in the screenshot.
Vincent
Unread post by Vincent » 29 Jul 2007, 14:19
Insert an Interface Desing/Text (comment)
Type any text in its properties
Change its size
Have a look to your patch : no text.
also:
Ctrl+Drag links its inlet to its outlet
Please report bug at contact@sensomusic.com, it will be easier to organize debugging.
vincent michel
composer & novelist
Users browsing this forum: No registered users and 629 guests
