I would like to see the loading of samples by selecting the folder.
I have bundled kits, and libraries that would benefit from this. At the moment I have to enter each folder and select the contents,making it difficult to load several soundbanks at once in a sampler.
Load samples by selecting folder
r.erorr
What do you mean by "loading of samples by selecting the folder"?
I'm looking for good sample manager soft, but unfortunately theris none satisfactory. It woud be nice if we coud transform usine like that.
sephult
So if I am using the list manager, I would like to just click and open the folder with all of it's contents populating the list manager.
As of now, you have to enter the folder and select all, then add to put in the manager.
-s
-s
- senso
almost implemented yet : the multi select is allowed in the openfile dialog window.
click "add files", select your folder and presss ctrl+A to select all files.
it does the trick?
it does the trick?
