Chromecast...
Chromecast is made for home-cinema and I'm not sure it's suitable for pro broadcast on stage.
But not tested yet.
If chromecast becomes a standard we will implement it. Actually we can't take the decision.
But not tested yet.
I think Chromecast is good suggestion. The same for AirPlay and Miracast or any other DLNA network possibilities. With respect to professional standarts I could argue that, even software itself is solid, a lot of patches(+ VST) are like experimental sub-programs and hardly stable, thought usable anyway.
PUSH!
I was wondering ..is it possible to use DLNA devices as separate audio outputs? ..maybe not directly in Usine, but thru facilitating an external streaming client? i was looking into ReaStream from the ReaPlugs-package, but cant get it to work. Maybe Jack could be a solution..anybody got hands-on experience with that?
Setup would be something like 6-8 DLNA devices running on Up2stream HW. Goal would be to use a surround setup in Usine thru a grid of those devices. Latency isnt a big problem..just basic waveforms for intonations and tunings
tnx,
tnx,
it's funny, I've forgotten this post from 2015...
yep sorry..but this was the only thread discussing DLNA in the forum PLUS i wasnt in the 'mood' for starting a new one. i'm still puzzled, why the whole upnp/DLNA isnt a bigger thing regarding small scale audio installations, impro and such..
hello,
I don't think it's targeted for pro audio /video ?
We are more focusing on AVB and ADM standards.
no, it's not very professional but i thought, it might be a low threshold approach to surround sound experiments..also regarding motion kit. i will give it a try with jack..tnx
I think you need something like Voicemeter or Virtual audio cable. afaik HH4 doesn't support Jack yet.iococoi wrote: ↑18 Mar 2021, 15:09PUSH!
tnx,
jack audio should work, with the Asio Router ?
yes..jackrouter works fine..but native support would be nice..bitwig f.i. got it..
i have found a few other solutions like audiophile upnp renderer and such..also the voicemeter-universe..
will update, if something spectacular should happen..
Users browsing this forum: No registered users and 103 guests
