Morpsound Feature request
stpro
Unread post by stpro » 06 Sep 2015, 16:01
hi
i need the real morphing between 4 sample sound source, this is a great idea i saw kymax 4 sample sound morphing and liked it very much.
I want to use the same for usine, Please help to improve.
I'll show a video
KYMA X 4 SAMPLE SOURCE SOUND MORPHING
Unread post by oli_lab » 06 Sep 2015, 16:29
can be done with the phase vocoder and data manipulation of the arrays
I'll give it a try.
Unread post by oli_lab » 06 Sep 2015, 17:05
this morph between 2 sounds, wouldn't be too much trouble to make it morph between 4 sounds....
http://www.sensomusic.com/forums/uploads.php?file=FFT%20morphing%20test%20oli_lab.pat
is it any good ?
Unread post by nay-seven » 06 Sep 2015, 17:09
We talk about this first on Facebook with Stpro and our first discussion was about the add-on Morphusine
of course this patch can't create a real morphing between waveform but here a try playing with gain's ( so it's more a mixer than a morpher)
Download
edit : cross posts with Oli, his patch is of course x100 better ;-)
Unread post by oli_lab » 06 Sep 2015, 17:50
stpro
Unread post by stpro » 06 Sep 2015, 20:02
it is amazing.nay-seven thank you
Unread post by nay-seven » 06 Sep 2015, 20:56
and to answer you Facebook question, it's easy to add more samplers to control
-duplicate the rack with the sampler and drag a new sample on the wave display
-set the binds number fader to 4 or more
-open the device panel (see user's manual if needed) and drag the new binds on the gain faders of the samplers
Unread post by nay-seven » 06 Sep 2015, 21:23
@ OLI LAB : yes, your's is definitively more a morphing tool :)
thanks
Unread post by oli_lab » 06 Sep 2015, 23:35
this morphing thingo is interesting but has to act on similar shaped samples (with different spectral content)
or pure continuous looped sounds.
my idea would be to have usine analyse freshly recorded incoming samples, so it can loop them in a way that the attack of both of them would be in sync...
I tried this morph with 2 bandlimited oscillators, detuned, one triangle and one saw type.... very good !
Users browsing this forum: No registered users and 81 guests
