Usine compatibility with external dsp
Shintylla
Unread post by Shintylla » 24 Aug 2015, 14:18
Is hollyhock ready for external dsp such Apollo duet?
Thx
sephult
Unread post by sephult » 24 Aug 2015, 15:11
If you are talking about UAD plugins, they should work. They are meant to run in any application that handles normal VST or AU.
I've never tried, but from what I have read it should not be anything different...just running externally.
-S
Trogluddite
Unread post by Trogluddite » 25 Aug 2015, 14:29
I've been using the plugins from my ancient TC Powercore DSP card inside Usine with no problems.
Unread post by nay-seven » 25 Aug 2015, 14:33
i think Shintylla is talking about the soudcard, not plugins ?
if yes, and if appolo duet is recognized as soundcard with correct drivers, must work
Shintylla
Unread post by Shintylla » 26 Aug 2015, 07:10
Thank for the answer,
*Nayseven:
I was talking about uad plugins.
Bye
Unread post by senso » 31 Aug 2015, 10:49
yes UAD plugs are compatible with Usine.
Users browsing this forum: No registered users and 297 guests
