use an ipad as a touch screen in Usine
Unread post by senso » 13 Aug 2015, 16:04
hi to the community.
I've just installed Duet Display app http://www.duetdisplay.com/ and I must admit that it WORKS ! (PC and MAC, tested on MAC)
Now:
- put patches in the toolbar,
- adapt zooms,
- disable 'auto reorganize' option of the toolbar
- put the toolbar on the ipad (viewed as a display monitor)
You can use touch controls on the ipad, unfortunately it's only mono-touch (because the touch events are transformed into mouse events). But not so bad.
It cost 15€
senso+++
joffo78
Unread post by joffo78 » 13 Aug 2015, 17:39
Personnaly i use idisplay for android and ios http://www.getidisplay.com/ it costs 3,99 euro and it works to ;-)
Unread post by senso » 13 Aug 2015, 18:01
I wanted an USB connection. does idisplay works in USB or wifi? not clear on their site.
sephult
Unread post by sephult » 13 Aug 2015, 18:26
That's awesome, I've used VNC viewers before and actually was looking at this at one point.
Now what I want is iPad on the PC so I can use my iPad like a VST. :)
-s
joffo78
Unread post by joffo78 » 13 Aug 2015, 19:29
It works in both solutions ;)
secretkillerofnames
Unread post by secretkillerofnames » 20 Aug 2015, 05:42
Air Display 3 also works. It's best with the USB cord as Wi-Fi / Bluetooth is too laggy.
I think mono-touch is a bit limiting for serious use and there is still a bit of lag compared to mouse usage but it's pretty useful in my setup where i'm attempting to separate from the main computer + monitor when playing.
Unread post by nay-seven » 20 Aug 2015, 12:09
tested with a cheap android tablet and Mac 10.8.5
Idisplay don't work in usb here, works in wifi but not great , resolution issues and not handy
Air display 2 (3 works only for ipad) works fine (great with the Tool box) in wifi but a bit laggy, hope they'll update the 3 version for android
