Normalize
CleverConQueso
not perfect but maybe could use wavform display with a (abs) + max_array module to get the approximative peak (as its a low rez proxy, but think it would be ok in most cases) on the fly, otherwise i think this can only be done with sdk or script (if binary load/read has been implemented in scripts, not sure if yet) then scanning raw data via a loop to get peak and adjust compensating level according to this.
something like this
(tho think maybe should subtract a little margin out of 1/x to prevent eventual clipping if ever there were higher sample values in files not catched by the wavform array)
something like this
CleverConQueso
Genius! Thank you so much.
well done FX23
CleverConQueso
TIL: There's a normalize button on the sample player. Just had to look for it harder.
Still, I like the super slick solution proposed above.
CCQ
CCQ
that's what i said myself i thought i had seen it before, also went too quick and missed it^^
Users browsing this forum: No registered users and 34 guests
