The object/patch currently selected (white box around), would be a good cue for this.
I would like to see this value/flag available on objects or even the patch module itself.
A useful example I am working with at the moment is using a listbox.
I would like to use some keyboard keys to navigate this list, unfortunately I cannot find a way around if two or more of the patches are used.
All listboxes will follow the key pressed.
If the listbox or patch settings had an option to identified it was selected.... at least some logic could be used to disable the ones who are not currently selected.
-s
It is currently 27 Nov 2026, 20:37
Object/Patch Selected flag
Return to “Suggestions & improvements”
Jump to
- News
- ↳ News
- English Forums
- ↳ General discussion
- ↳ How to send a Bug Report
- ↳ Suggestions & improvements
- ↳ Patching questions
- ↳ Add-ons discussion
- ↳ Additional Packs
- ↳ Module development SDK
- ↳ Artistic Zone
- ↳ Registration procedure
- ↳ Manuals & Wiki
- Forums Français
- ↳ Discussion générale
- Home Board index
- All times are UTC+01:00
- Delete cookies
- Privacy
- Terms
- Contact us
Powered by phpBB® Forum Software © phpBB Limited
