Layout Style light
Unread post by cmodica » 13 May 2015, 21:32
Hi every body.
I work with Usine Hollyhock II on Macbook pro, OSX with retina display.
I work very often outside in strong working condition. And each time i am angry about the dark interface. The retina display is good but bright, and with the black général color of Hollyhock it is very hard to see my screen. I can see myself very well but it is not that i want :P
It is better if i change each Rack Background color with a light Grey.
But the best should be a Layout Style ''light and bright'' for special use under the sun ...
Thanks.
Unread post by nay-seven » 13 May 2015, 22:59
i know the user Vincent has created a small utility to create some layout style, will ask him if he can upload it as an add on
the bad news is that it's a windows appz, have you access to some PC ?
Vincent
Unread post by Vincent » 14 May 2015, 00:40
Yes, it's a Windows app, using Windows stuffs for colors. I'll upload it tonight if possible.
You could bring your color set file on a PC, change the layouts and copy it back on your Mac. Not easy... :(
Regards.
EDIT - uploaded : HH Palette-manager
vincent michel
composer & novelist
Unread post by cmodica » 14 May 2015, 14:40
True not easy but i have an old PC at home and i will try your appz.
It should be an interesting improvement to change the Usine Layout style when needed !
Thanks.
Unread post by cmodica » 14 May 2015, 15:10
bad News, it doesn't work on my old WinXP Computer : ''It is not a valid Win32 appz'' ...
Could you send me a Bright layout (with bright grey instead of black and Dark grey) ? If should be great.
Thank you for helping.
I test with cross over for Mac OSX but it seems not work ...
Unread post by nay-seven » 14 May 2015, 17:00
Here one with a light and an ultra light version, maybe it can suit your needs
Download
Unread post by cmodica » 14 May 2015, 21:04
Wonderfull !!! Thank you very much !!! I test it tomorow. We play a public presentation of our work in progress in a sunny place.
Thank you, thank you !!!!
i hope that i can help you one day, because you erase my stress tonight !!!
:cool:
Unread post by cmodica » 15 May 2015, 21:17
It is very useful the light color set for working outside. Today i can see my screen.
Unread post by nay-seven » 15 May 2015, 21:22
good news
really glad to help you !
Users browsing this forum: No registered users and 301 guests
