user module folder
Unread post by oli_lab » 13 May 2015, 13:13
I have a folder on my computer to store my own user modules, in C:hollyhock/persolivar/usermodule
what will happen if the same module is present in that folder as well as in the usine's addons folder ?
wich one will load when a patch is loaded ?
I am concerned with modules not updated online while I made minor updates on the ones in my personal folder
martignasse
Unread post by martignasse » 13 May 2015, 14:33
oli_lab wrote:Hi,
so, you access this personal folder by the library tab, not the module tab ?
i think the patch will try to load the module you used when you constructed it, but i have to check with senso
what do you mean by 'not updated online ?
martignasse
Unread post by martignasse » 13 May 2015, 16:10
ok, so here is the behavior of usine to locate a module:
1°) search in the usine distrib folder (and subfolder)
2°) search in the personal library folder
3°) search at the same level of the patch/workspace file (useful in case of exported workspace)
if more than one file in one of those stage, the first to come up (alphabetical exp^loration of folders) is the one used
Hope it help
Unread post by oli_lab » 14 May 2015, 10:45
yes
I made minor changes on my own modules but not yet uploaded the new ones on the addons page
>>Hope it help
yes it does
the priority should be to seach for the personnal folder first, makes life easier for the module developper, isn't it ?
many thanx
Users browsing this forum: No registered users and 5 guests
