know bugs in the 3.04b
Unread post by senso » 09 Jul 2007, 08:56
I have noticed a bug in the 3.04:
the sampler doesn't work properly in reverse mode.
I'll post an update soon.
jean-marc duchenne
Unread post by jean-marc duchenne » 09 Jul 2007, 12:06
I don't know if it is a bug : when the objects stack in the right patch list is longer than the screen height, only the first ones are visible and I have not found a way to make the list scrolling.
There is a triangle at the top that I supposed is make for this, but it has no effect when I click on it. I suppose also that there must be another triangle at the bottom ?
Precision : my screen is 1200 pixels height and the objects are XY pads.
Suggestion : option to align the objects on two columns if there is not enough room ?
Unread post by bsork » 09 Jul 2007, 13:33
Hi, you should see two triangels at the top of the patch, between the the inputs/track name and the interface design elements: to the left scroll up, to the right scroll down. It should look the same whether in patch edit, grid or sequencer live mode.
I just downloaded and installed 3.04b on my job computer (laptop XP C2D), and it's working fine here on both the internal monitor (1400*1050) and an external monitor (1028*1024) which is used as the primary monitor. I have a feeling that the scrolling is a bit slower than what I'm used to though, but I'm not quite sure...
jean-marc duchenne
Unread post by jean-marc duchenne » 09 Jul 2007, 13:45
Yessss, thanks, I had the second triangle at the right edge just hidden by the tab of another app. No chance...
Yes, the scrolling is slow but it works.
Vincent
Unread post by Vincent » 09 Jul 2007, 18:26
Suggestion about that greedy scroll, specially in the General Remote window:
scroll range of half of the window? or five lines?
vincent michel
composer & novelist
Unread post by senso » 09 Jul 2007, 18:40
The scroll speed is curious: sometime speed, sometime slow without any real explanation...
moody33
Unread post by moody33 » 13 Jul 2007, 01:36
About the sampler: overdub recording don't seems to works. It seems to append the new recording once the original loop lenght has been reach... I am probably missing something?
Unread post by senso » 13 Jul 2007, 08:56
I'll take a look
Users browsing this forum: No registered users and 425 guests
