deleting file
percuson
Unread post by percuson » 08 May 2015, 02:51
Hi alltogether!
I am using the sampler & recorder module to record and save files on my harddisk. This works fine in the background.
But is there also a way to delete the saved files without prompting?
Thanks!
Unread post by nay-seven » 08 May 2015, 09:17
Not sure to understand in which conditions you need this but currently, no you can't delete files without prompting
percuson
Unread post by percuson » 11 May 2015, 05:52
Actually I am working on a looper with undo/redo function. It saves the every new layer as a combined file to the harddisk and recalls the previous file when doing an undo. It seems to work pretty well. But I wanted to erase the files when resetting the sampler/looper since it just litters up the harddisk. So until now I have to do it manually.
Anyway... thanks for the answer! I can deal with it. It was just the idea to make my looper more userfriendly for others...
