User curves
jean-marc duchenne
Unread post by jean-marc duchenne » 08 Jul 2007, 14:30
There is some questions / suggestions regarding how to record User curves in realtime in the sequencer :
- I have not found how to MIDI record several User curves at once (for example for a XY pad)
- also, is it possible to set a specific CC number to each curve ?
- when a curve has a lot of points (100 or more) it becomes very slow to edit them
- how to select several points together (lasso, time selection ?) to move or delete them ?
- when I clear an curve to erase all the points, the name is also erased
- could be the curve drawn during the recording ?
- is there a possibility to record the User curves within the plugin GUIs objects ?
- perhaps that a "fader input" for the User curves will be a possible solution ?
Thanks.
Unread post by senso » 08 Jul 2007, 17:38
hello, thanks for you feedbaks
many interesting points.
Yes!!!
In fact I will add a CURVE VALUE inlet and a REC button.
This will solve all your problems!
Actualy, impossible but with the FADER+REC inlet it will be possible.
For curves recording, usine takes any incomming message. So you cant specify a CC number.
With the REC + FADER you will be able to do that!
This is caused by a long process in storing UNDO files.
Problem solved now. (next release)
Sorry, no way actually.
I'll find something
you are right, but I can change this behaviour.
normaly it should. If not, it's a bug. I'll take a look.
Vincent
Unread post by Vincent » 09 Jul 2007, 18:30
Hey jean-marc, you're becoming a sequencer-master!
vincent michel
composer & novelist
