FastScript - Browser Code Snippets
sephult
Unread post by sephult » 21 Apr 2015, 20:07
Hello!!
So I was thinking, I have seen other script and programming languages that provide a basic "code snippet" browser.
I think it would be very cool if you could select a line of code, or basic syntax (like a FOR loop template) and be able to drag and drop, assign shortcut keys, etc to place in the script.
This would make scripting quicker and more efficient, hopefully allowing to build up a standard library.
Basically the ability to capture text into a file which is visible in a browser tab, that can be dragged and dropped...maybe possibly a shortcut assignation.
-S
Unread post by senso » 28 Apr 2015, 18:09
Unfortunately the script engine is not Delphi.
And your suggestion is very difficult to implement.
I prefer keep focused on the audio core?
