Record panel closed
Unread post by gwennaelle » 18 Apr 2015, 08:37
I have hot a little problem. The " record" panel doesn't show its contents, so I can not record .
I've found no solution on the forum.
When I open now a workspace realised before this problem becomes, the panel is normally open, but when I create a new workspace, the panel problem is still there.
Should I click on "delete" in Direct-to-disk?
What does mean "delete all items in the Direct-to-disk" ?
Would you know how to open it again?
Thanks a lot
Gwennaelle
Unread post by nay-seven » 18 Apr 2015, 09:34
Not sure to understand your question
do you mean you populate the record to disk panel, save your workspace and when you open it again the record to disk panel is empty ?
mean it's clear the items ( devices, racks) of the direct to disk ( as said on its wiki page )
what's happen when you click on its icon..?
Btw, you have create several post before and people answer you, can you please answer these posts and tell us if other problems are solved ?
symplx
Unread post by symplx » 27 Apr 2015, 04:11
Click and drag the output of each rack to the 'direct to disk' pop up. Unfortunately there is no global output record. 'Direct to disk' will create a file for each rack output. They will need to be mixed in a DAW. Does that help? Your question is vague.
Unread post by nay-seven » 27 Apr 2015, 08:33
@symplx : i have to precise your answer :
No, you have to drag and drop the rack itself ( click on its header panel)
of course yes ! you can also drag and drop your main audio output device from the devices panel
note you can also drag and drop inputs devices too if needed
Unread post by gwennaelle » 28 Apr 2015, 12:20
What I wanted to say by "the record" panel doesn't show its contents" is in the picture.
http://www.sensomusic.com/forums/upload ... rement.png
So I couldn't access to the red buton.
And nothing happened, when I click on its icon.
As I didn't success to solve the problem, I decide to create a new workspace, re creating the same tracks...
Regarding what insert in the direct to disk, I inserted different types of outputs (stereo, or to the 8 outputs), but did not think to integrate racks itselfs.
Thank you, it can help !
Unread post by nay-seven » 28 Apr 2015, 12:56
I see you use an old version ( 060) so the first thing could be to update usine with the fresh new 068 ?
many small bugs have been fixed since 060
Unread post by gwennaelle » 28 Apr 2015, 16:02
Ok, thanks.
Just, when I change version, did I loose my projects? Because they aren't no more visible in the interface of new versions ...
Unread post by nay-seven » 28 Apr 2015, 18:25
No you can't loose your previous projects, download the new version and use the import old setup in the setup panel
this way, after a restart you'll find your last recent projects in the startup page and Usine will be activated
Users browsing this forum: No registered users and 626 guests
