I would like to send my signal 8 Speakers, by 8 outputs of the Fireface UC, with the ability to send in all speakers simultaneously. The problem is that I find "only" the Surround 8 Out and the Surr Pan which is focused on one or two points.
Would you know how to send in all speakers?
Thank you
Gw
Multidiffusion
You can modify the devices in the device panels to wire your own setup.
You just need to enable all of the Inputs/Outputs from the settings panel.
Then open the devices panel, select add input/output for what you need.
Next double-click the new device added in the device panel.
You can just wire the IO for all the inputs and outputs you need.
In your patches you can add additional outputs or modify the device output so all the signals merge if thats what you want.
-S
-S
Hello Sephult,
So I did this
But I have sound only in Audio from Usine 1 and Audio from Usine 2, nothing in Audio from Usine 3... to 8.
Would you know what's wrong?
Gw
So I did this
Gw
you could try to use an audio matrix nsources x 8 outputs.
you need also an audio device (with 8 inputs) in the bottom part of each rack so the 8 audio channels will be transmitted to the 8 outputs of the sound card
Hi gwennaelle,
It seems your image is not loading at the moment.
I will try to see if I can find it later.
As Oli said, you need to have your audio device enabled for the outputs, and modify the Device panel - Device you are using for output as well.
As a default only Audio 1 and Audio 2 are wired, you will have to wire an output Device, so that these also go to the rest of your audio ports.
You have the choice to wire your patches through multichannel, or you can just use a Stereo pair through your patches and split in the output device to all your channels.
-S
-S
Hello Oli, and Sephult,
Ok,Thanks. I had the device, and in the patch, have linked the matrix, this is ok.
Even one thing to solve. Depending on the model of the original in stereo, I tried to create a control volume for 8in, 8out, but I didn't understand how (where) to use it (the volume) (is it the gain?). And I could'nt reproduce the patch, because I didn't find the "audio thru" fader (the copy/past doesn't match). Would you know?
Thanks.
Gw
Thanks.
Gw
