Hi there.
Anyone out there with a Mac, and an iPad with the AudioMux app (streams audio via the USB connection)?
I've got a curious issue that I'm reluctant to post as a bug yet.
If I select the AudioMux device as an input - HH seems to mute the output.
Audio level shows as coming in and going through to the master - yet there is nothing.
If I record direct to drive - there is sound recorded - it just does not play through until I remove the AudioMux device from input.
I've tried with a Focusrite Scarlett 18i8 and the built in audio on two separate Macs - both running OSX 10.9.5
I've also tried making an Aggregate Device with the Audiomux and Scarlett to no avail.
I've check and am not having this issue with Ableton Live, Tracktion 6 or Reaper.
chrs
][oyd
Possible AudioMux issue
You can post a bug report, if you don't find solution
but currently, Usine generally prefer using the same audio device as input and output
secretkillerofnames
Thanks for the reply. When you say "generally prefer" do you mean "definately must"?nay-seven wrote:but currently, Usine generally prefer using the same audio device as input and output
Users browsing this forum: No registered users and 309 guests
