leap hand choice
gercha1
Unread post by gercha1 » 25 Mar 2015, 10:28
hi
and first thanks a lot for the leap developpement
very nice tools ! very usefull for me !
I've try to modify the leap patchs because i need to serapate the two hands
for a project to have for example one leap patch in the right hand and another to the left hand,
i build this sub patch ,
it works almost but when the two hands come in the same time
there's sometimes bugs
here the application in theleap shots
if some one as better idea for patching
thanks
Unread post by nay-seven » 31 Mar 2015, 15:55
Here an other patch I've begin , not finished too
but maybe it can give you some ideas
Currently you can use, left hand alone, right hand alone
if you want use both, start by the left and always take the right off first ( that's the issue to finish)
Download
sephult
Unread post by sephult » 31 Mar 2015, 20:52
Leap Two Hand - Beta
Hi guys!!!
I was just talking to Senso about this, said that the data coming in causes the array to not specify which hand belongs to which set of indexes.
Well I made a script to fix that.
There is still a bug in this I am working with Psudaform...The Top two switches must be set to record with hand...I am modifying the Rec XY for a triggered record as an option and have just not finished.
-S
sephult
Unread post by sephult » 31 Mar 2015, 21:00
Nay there is the script you can steal, The array indexes in the script could be adjusted but work as is.
The problem I was finding was Thumb versus Pointer Finger. Seems the thumb gets mistaken as pointer (maybe my thumb is too big...lol)
Well I found if you spread your fingers and place your hands flat, then enter...the pointer picks up better.
-S
sephult
Unread post by sephult » 31 Mar 2015, 21:16
sephult
Unread post by sephult » 31 Mar 2015, 21:49
Leap Recorder - Two Hand - Working
I've got the bugs fixed, should be working now for two hands.
Option to disable record on hand movement and use the record button.
Each hand has option to do plain through-put without record by switch, as well as re-triggering previous playback of the recording with the switch next.
There are two MIDI outputs which can be independently modified, and the matrix specifies which MIDI module it is to go to and which Code. M1C1 = Midi Module 1, Code 1, etc...
So you can route the hand XY to the specific.
-S
Unread post by nay-seven » 31 Mar 2015, 22:56
Whaoo, i suppose i need to change your username to MasterSephult now ;-)
will be a useful tool, definitively!
sephult
Unread post by sephult » 31 Mar 2015, 23:22
Well nay,
I wasn't joking when I told you Hollyhock is about the only thing I do :)
Really need senso to put an hour usage on this thing...hahaha
Here soon I am going to need Usine rehab.
-S
sephult
Unread post by sephult » 31 Mar 2015, 23:23
LeapPalm
Here is another patch I just built for Leap, basically the same thing but just a Two Fader Control for the Y and two hands.
Recognizes which one is which regardless and sends out CC associated.
-S
gercha1
Unread post by gercha1 » 02 Apr 2015, 10:42
very good job sephult
very usefull for me,
thanks for the script !
Unread post by SylvainT » 03 Apr 2015, 09:37
very usefull
not so precise, due to Leap technology I suppose
thanks
Users browsing this forum: No registered users and 47 guests
