list of 50 new modules
3D
3D points editor
Line Array to 3D
3D Transform Rotation X
3D Transform Rotation Y
3D Transform Rotation Z
3D Transform Translation
3D Transform Scaling
3D points to Matrix array
Matrix array to 3D points
3D get Points (XYZ)
3D Set Points (XYZ)
Array
FFT Forward (Up to 4096 Size)
Array Random
Array Combine Inverse X3
Array Combine X3
Get Array nb rows
Set Array nb rows
Get Array nb lines
Set Array nb lines
Audio-Panners
Distance Based Amplitude Pan(DBAP) 3D
Quadratic Distance 3D
Audio-Samplers
Grain Sampler & Recorder (Updated)
Grain Sampler (Player) (Updated)
Midi Sampler
Color
Color Palette
Data-LFO
LFO (Combined with Sync, and added Saw and Inverse Saw)
Interface Control-External Devices
LeapMotion[v2.0]
Interface Control-Usine Panels
Current Patch Settings (additional settings, randomize patch, edit patch)
Current Rack number
Grid Section settings
Grid Settings
Master Panel (additional IO)
Master DMX Panel
Rack Settings (minor IO changes, rack type, fit grid line number)
Setup panel (additional IO for new functions)
Fader (Design changes, text on top, dashed faders)
Switch (additional LED)
Light
Smooth Attack Release
RGB to Usine color
Usine color to RGB
Clear Artntet Channel
Math
A^i(int power)
X*X(sqr)
Matrix
MX Exclusive mode [fastscript]
Matrix - Audio Mix [v2.4]
Matrix - Data Mix [v2.4]
Matrix - Midi Mix [v2.4]
Matrix - Display or Set [v2.4]
Strings
Path Delim[fastscript]
Sub File Ext[fastscript]
=(string)
Dispatch String(1 in->n out)
3D points editor
Line Array to 3D
3D get Points (XYZ)
3D Set Points (XYZ)
Array
Array Random
Array Combine X3
Get Array nb rows
Set Array nb rows
Get Array nb lines
Set Array nb lines
Audio-Panners
Audio-Samplers
Midi Sampler
Color
Color Palette
Data-LFO
LeapMotion[v2.0]
Current Rack number
Grid Settings
Master DMX Panel
Light
RGB to Usine color
Usine color to RGB
Math
A^i(int power)
X*X(sqr)
Matrix
Strings
=(string)
There are 50+ and a lot of rework on other modules for bug-fixes, changes for design settings, etc.
Also there are some additions to fastscript language such as Creating Directories, and Capturing the path of the current directory.
As far as Library Content, there is a lot of new interesting items such as:
Groove machines - GROOVE Steps
Grain (5 new patches) - GRAIN Micro Loop is very interesting
Leap - There are many new patches including a Grainplayer, and Granulator FX driven by Leap Motion
Midi - Midi Xcros Sampler, and MIDI Randomator are very interesting patches as well.
Pads - 3 new patches including a 16 pad trigger
Spectral - Many new and interesting concepts utilizing the updated FFT
Hope that helps
It's not the complete list by far, but I think there is way beyond 50+ new items to explore
Maybe can get the list from Senso or Nay and put in the Wiki.
-S
-S
ok, it's clear now. Thanks again!
The VU Meter is updated now as well so you can modify the colors from the standard green.
Users browsing this forum: No registered users and 833 guests
