FastScript - Find index of smallest number in an Array
sephult
Unread post by sephult » 08 Mar 2015, 16:33
Hello!
So I have run into a problem at the moment I cannot wrap my head around.
I need to find the index of the smallest number in an Array, I know in several programming languages there are functions to do this.
I thought this was quite an easy thing to do and I have done before in other languages, however I am starting to become stumped (probably just finding a downfall of pascal??).
Definitely wasn't expecting to get hung-up by this.
So below my solution was a simple conditional check within a For loop. If smaller than the variable then make the variable equal to the iteration/index.
Keep checking for smaller numbers. However, the result of oldest is always Zero even when the smallest number exists in [1].
So Process procedure decides and receives the event trigger, if a condition exists secondary procedures are executed which contain this code below.
The variable oldest is a value from 1 to 16.
Anyone have a clue as to why this may be, or have some guidance to an alternative method to perform this?
Code: Select all
  oldest:=17; //Initialize for detecting oldest index
  //Search for lowest number in array and purge
  for k:=0 to 15 do begin
    if order_array&#91;k&#93; < oldest then begin
      oldest &#58;= k;
    end;
end;
-S
Unread post by bsork » 09 Mar 2015, 08:31
You mix up two things here; the values to check, and the array index.
You could do eg:
Code: Select all
oldest &#58;= 0;
FOR k &#58;= 1 TO &#40;ARRAY_LENGTH - 1&#41; DO BEGIN
  IF &#40;order_array&#91;k&#93; < order_array&#91;oldest&#93;&#41; THEN
     oldest &#58;= k;
END;
sephult
Unread post by sephult » 09 Mar 2015, 13:35
Awesome thanks for the guidance bsork!
I was getting totally stumped for a moment. Below is the code that is working for me now.
Was there any reason why you started the array index as 1, or was this just a mistake? Had me curious.
Code: Select all
  oldest&#58;=0; //Initialize for detecting oldest index
  for k&#58;=0 to getarraylength&#40;order_array&#41;-1 do begin
    if &#40;order_array&#91;k&#93; < order_array&#91;oldest&#93;&#41; then
      oldest &#58;= k;
  end;
Again, Thank you Bsork!!
Best Regards,
-S
Unread post by bsork » 09 Mar 2015, 14:42
I startet at 1 as we are comparing pairs: When k is 1, oldest is always 0, when k is 2, oldest is 0 or 1 depending on the previous test, etc...
It looks a bit more obvious (to me, at least) if the variable name is changed from "oldest" to "lowest" or something similar.
sephult
Unread post by sephult » 09 Mar 2015, 15:50
Bsork,
Yes I agree that the name should be changed from oldest to lowest for a generic.
In my specific script I created a Dynamic Channelization, so for the procedure I am trying to actually determine the note that has stayed in the array the longest.
If all channel slots are empty, I purge the oldest one to make room for the next.
It is actually working quite nice now, I have been working on implementing scala tuning into Hollyhock. As of now, I have a format that does direct Frequency output, I am now working on the MIDI pitchbend. Once finished my goal is to provide Alternate tunings not only for single notes, but for chords.
-S
Users browsing this forum: No registered users and 51 guests
