I have looked at the IML information on the website, but I am not sure if it is complete, so a few questions:
1. Is it possible using IML to delete a "wire" by only specifying one end of it ?
Obviously this could end up deleting multiple wires if a particular parameter is wired to several places.
For example if you do not know what is on the other end of the wire but you want to delete the wire anyway.
Or if you modify a script and the parameters are renumbered, you can end up with "broken" connections being shown in the patch GUI - which look like unterminated wires. These wires only have one end so you cannot specify the "other" end in order to delete it.
Or is there a way to specify something like ANY_MODULE, ANY_PARAMETER for the other end of a wire ?
2. Is it possible to trace the path of wires from one end using IML ? For example if would be useful if a script could examine what is connected to one of its parameters in order to debug incorrect operation ?
Simon.
It is currently 27 Nov 2026, 14:31
IML for unterminated wires
Return to “Patching questions”
Jump to
- News
- ↳ News
- English Forums
- ↳ General discussion
- ↳ How to send a Bug Report
- ↳ Suggestions & improvements
- ↳ Patching questions
- ↳ Add-ons discussion
- ↳ Additional Packs
- ↳ Module development SDK
- ↳ Artistic Zone
- ↳ Registration procedure
- ↳ Manuals & Wiki
- Forums Français
- ↳ Discussion générale
- Home Board index
- All times are UTC+01:00
- Delete cookies
- Privacy
- Terms
- Contact us
Powered by phpBB® Forum Software © phpBB Limited
