.peak files everywhere?
osha
Unread post by osha » 14 Jan 2015, 10:27
Hi
Is there a way to stop Usine Hollyhock placing what I presume are analysis files in the same folder as all my audio. It's a bit messy!
sephult
Unread post by sephult » 14 Jan 2015, 18:16
Interesting question.
Could create an executed batch file to delete all the .peak files. I use simple batch files a lot of times to search for things to sort and delete.
Could also execute it from a patch.
-S
osha
Unread post by osha » 15 Jan 2015, 01:46
Mmm that sounds like windows....I'm mac. I was hoping for a preference but I don't think there is one.
Unread post by senso » 15 Jan 2015, 09:04
the .peak file is used to accelerate waveform drawing of audio files.
It's a very common behavior, like for example in reaper.
No way to disable the creation. If you delete them they are automatically recreated next time you load the file.
In the next version, this file will be optional, depending on the memory location (memory or file)
Unread post by 23fx23 » 15 Jan 2015, 11:11
can try to sort by type maybe? thats what i do personnally
osha
Unread post by osha » 15 Jan 2015, 17:54
senso wrote:In the next version, this file will be optional, depending on the memory location (memory or file)
great that was my hope. Thanks
Mothballs
Unread post by Mothballs » 16 Jan 2015, 01:21
I am also often annoyed by .peak files cluttering up audio folders. What would be helpful is an option to store them all in one out of the way location as is found in Reaper and indeed most DAW applications.
Users browsing this forum: No registered users and 383 guests
