Hi all,
my problem is the following: I want to write a score for a large number of (mainly) external instruments controlled via OSC.
I understand that this would be pretty easy using Usine OSC functionalities, as I could create different modules which fit any particular instrument "interface", and score their behavior with the Sequencer.
Now, I wonder if there is also a way to use Usine scripts to create such "score" (i.e. to create algorithmically tracks and their content "a la Iannix", I would say).
Thanks for your help
Marcello
Scripting tracks/automations?
Hello and welcome karl,
Don't know anyone using script in live mode with Usine, but maybe you can precise what your needs ?
if i correctly understand your question, solution to what you want to achieve is to create ptDataFader type output(s) of the script and connect it to OSC module..
Users browsing this forum: No registered users and 349 guests
